Admin Toolbar
Discussion in 'GeoCraft WordPress Theme' started by little hero, Jul 20, 2013.
  1. little hero
    little hero New Member
    Is there any way to get the admin toolbar showing with this theme, I feel really lost without it!
  2. tobyb
    tobyb Active Member
    World Wide
    Hi, if it is the WPress admin toolbar down left hand side of admin you are looking, look at the very bottom on left and you will see last a small arrow, click this and tool bar will open again, touch arrow again and toolbar will collapse again, hope this helps.
    Tob
  3. little hero
    Hi, no I mean the black one at the very top of the site when viewing it if logged in.
  4. tobyb
    tobyb Active Member
    World Wide
    Sorry, be lost there, the only other one I have used is the screen options for WPress at top right of wp-admin.
    Hope you get sorted.
    Tob
  5. little hero
    It's this one you see when viewing the site, not in admin dashboard.
  6. tobyb
    tobyb Active Member
    World Wide
    Hi, yes that one only appears when you are logged into admin and viewing site, should be there for you ok.
    Tob
  7. little hero
    No not there at all for me :(
  8. little hero
    It works on the default theme. I've disabled all plugins but it won't show at all.
  9. spoonboy90
    spoonboy90 Active Member
    little hero is correct, in geothemes the Toolbar doesn't display when viewing the site... dispite the option being checked in the admin profile. Only comes up if you're in /wp-admin. Well at least not for me or little hero!
    little hero likes this.
  10. Nitesh
    Hello All,
    For this go to the
    geocrafttheme\admin\geocraft_functions.php
    and comment out code at line no 674
    spoonboy90 and little hero like this.
  11. little hero
    Thank you! Works perfectly :)
