Advice for a Bilingual English / Arabic site
Discussion in 'GeoCraft WordPress Theme' started by websitesdepot, Nov 28, 2012.
  1. websitesdepot
    websitesdepot Guest
    Hello, and thanks in advance for any help.
    I'm basically trying to create a paid and free listings site, but it will need to be able to be changed between English and Arabic. I'm using WPML, and it's helping to translate some of the strings over. I'm still having problems with the whole RTL thing, and how that works. I didn't see an RTL.css file either, nor a custom.css, so that I don't overwrite anything on upgrades. I would like to have the menu going from RTL on Arabic and so on...
    My other concern is with posting listings. When I go to the arabic version of the site and try to create a listing, it says it's being reviewed and everything seems to go through fine. When I go to approve it in the backend, it's like it's in English, unless I change the dropdown to specifically choose the language as Arabic. Is there any way to set ads posted under Arabic to show up there?
    Lastly, I said that it will function in both English and Arabic with Payments. How would I the payment part work out with the different currencies?
  2. Krish
    Krish Support Staff
    India
    In the Theme Options Panel, we have provided you the option to write your own Custom CSS under Styling Tab, putting the CSS over there would be safe as it won't be lost in the update. We don't develop and provide the RTL style for our themes, you would be required to do it on your own.
    The dropdown in languages would be appearing through the help of plugin, the best possible answer can be provided by the plugin author as why is this thing happening.
    There is an Option in the Themes Options Panel which allows you to choose between different currencies which are supported by Paypal. See attached image for reference.
