Affiliateshop not working
Discussion in 'Quick Online Shop WordPress Theme' started by pittyc, Jul 18, 2017.
  1. pittyc
    pittyc New Member
    Hi
    I am having trouble with the affiliate shop plugin. It is not downloading the products. It hangs and does nothing.
    Sometimes, if I refresh, the plugin will begin working again, but otherwise, it keeps freezing. Is there a problem with the plugin or could it be server side?
  2. akbar92
    It could be a server side problem, so you are requested to contact your host provider in this regard.
    Thanks & Regards,
    Akbar
