After colorway update home is gone
Discussion in 'ColorWay WordPress Theme' started by nicolaivarney, Mar 14, 2015.
  1. nicolaivarney
    nicolaivarney New Member
    Hi everyone..
    After colorway update 3.3 (i think) my frontpage is suddenly gone.. was just using the regular "home" with the banner and the stuff, but suddenly it doesnt appear..
    Suddenly my homepage disappeared and is replaced with my blog, and i cant figure out why.
    Under Theme > Appearance > frontpage is set to on. It doesnt matter if its on or off, blog is still frontpage. So weird!!
    Furthermore i tried to find frontpage/home/etc. to make it a static frontpage, because the above didnt work.
    Not possible either..
    page is www.nicolaivarney.dk
    I know it will work again if i delete and go back to 3.1, but i'd prefer another way to fix it :)
    thnx
    /nicolai
  2. sameerwalkar
    sameerwalkar Guest
    Kindly check the mentioned settings mentioned in the provided image and also make the front page option to "On" from Theme > Appearance > frontpage:
    Sameer
