Ajax Upload.js
Discussion in 'ClassiCraft WordPress Theme' started by spottedvarennes, Feb 7, 2015.
  1. spottedvarennes
    spottedvarennes Member
    Hi, You know for the Ajax image Uploader in Edit_ad.php ? Its kind of buggy in chrome for me. When i click on one of the 5 buttons, sometime the button does nothing. It seems to only happen on Chrome.
    But I check on your live preview, and the bug is NOT there, it works perfectly on your site. (I tried with a fresh WP install and with the package classicrafttheme I downloaded from the member area, and the bug is there too. BUT, I noticed that the Javascript for the AJAX you use on your Live preview site, is not the same of what is included in our package.
    Can you please check whats the difference for Ajax Image uploader used in edit_ad.php in package v1.1.9. (member area) and the script you use on your Live Preview ?
  2. Pramod
    Pramod Guest
    Hello !
    We have checked theme and always image upload works fine.
    May be it taking time to load jquery which may unable to process the click action.
    Once complete website is loaded it will work perfect.
    Pramod
