Is it possible to disable the Ajax upload on the Add Listing page as it is preventing operation of a media plugin which allows uploaded image filenames to be changed to that of the Listing Title.
Hello, Thanks for contacting us, Will you please elaborate your query a bit more with the help of some edited screenshots of the concerned areas of your site. So that we can deliver you an exact and appropriate solution to you, Looking forward to hearing from you soon. Thanks & Regards! Akbar InkThemes.com PS: You can create your screenshots using screenpresso (http://www.screenpresso.com).
Hello Akbar I'm afraid a screenshot will not help or show what I'm after. Let me explain. I have installed a plugin which on upload will rename listing images with the name of the Listing Title. eg when the Listing owner of 'Sample Listing' uploads from the front end images for their listing, the image file names will be changed automatically to 'samplelisting1.jpeg, 'samplelisting2.jpeg etc. However the plugin developer has told me that there is an Ajax upload on the Add Listing page and in order for the plugin to work on the front end the Ajax on the Add Listing page needs to be disabled. How does one do that? Anthony
Hello, Hope you are doing good...! I just tried it from the front-end but didn't notice the issue as you mentioned above. The name of the image remains the same after uploading. Will you please allow us to check your website dashboard for once? Kindly send the below-mentioned credential details at [email protected] along with the thread link. WordPress Website URL: - WordPress Username: - WordPress Password: - We will try to fix your issue. Regards, Akbar InkThemes.com
