Aligning Test in Footer
Discussion in 'ColorWay WordPress Theme' started by 1stopnonprofitshop, May 13, 2016.
  1. 1stopnonprofitshop
    1stopnonprofitshop Guest
    How do you align the address where Phoenix, AZ is right under 1212 W. Sample Street? Also, how do I center the titles in the footer?
    Below are the codes for that..
    .footer-container .textwidget {
        text-align: center;
    .footer-container h4 {
        text-align: center;
  3. 1stopnonprofitshop
    The code worked to center the title in the footer, but when using both codes it also centered all the text in the footer (which I didn't want). I now have the titles properly centered, but just want to know how to move the second line of the address over so Phoenix is right under 1212.
    You can use any one of the code given below..
    .common.second p:nth-child(1) {
        margin-left: 65px;
    or,
    .common.second p {
        margin-left: 65px;
  5. 1stopnonprofitshop
    Now it moved Email Address over as well. I want "Email Address" to be directly under "Address"
  6. priya
    Alright...
    Second code will work for you...:)
