All the theme right alignment
Discussion in 'BlogSpring WordPress Theme.' started by feflores, Oct 1, 2016.
  1. feflores
    feflores New Member
    Guatemala
    Por favor, necesito ayuda !! No es así, pero todo tiene que alinear a la derecha y no hacer?
    Les dejo una imagen como esta ... Por favor
    www.MejorWeb.gt
  2. Naveen
    We can help you in that, but, It would be better for us to understand your query with the help of edited screenshot.
    Naveen Kolhe
  3. feflores
    feflores New Member
    Guatemala
    Thank you and solve the problem. But now I can not translate the template to Spanish of Guatemala. Already tried everything but I can not translate the whole subject. This does not work define ( 'WPLANG', 'es_GT'); I do not know what to do!! ; (
    I show some examples in this image but in the entire workforce in general. I have translated some manulamente but many are.
  4. Naveen
    Thanks for sharing the screenshot.
    You can share the list of the texts with translation strings that you are not getting translated along with your site credentials at [email protected]
    We will do the needful on your site.
    Warm Regards!
    Naveen Kolhe
  5. feflores
    feflores New Member
    Guatemala
    I have a list of what you want to translate. I need the entire site in Spanish. It is the language of my Market and pubic objetivo. What kind of credentials need to Evie?
  6. Naveen
    You can share your WordPress admin credentials at [email protected]
    We will take care of the things.
    Warm Regards!
    Naveen Kolhe
  7. feflores
    feflores New Member
    Guatemala
    Ready've already sent your user access data is Naween. I'm pending. Thank you.
  8. Naveen
    Hello Feflores,
    It would be helpful if you could resend the email along with this thread link.
    We are unable to find your email.
    Warm Regards!
    Naveen Kolhe
  9. feflores
    feflores New Member
    Guatemala
    Ya envié de nuevo los datos al correo: [email protected]
    Un saludo!
    Fernando Flores
    MejorWeb.gt
  10. Naveen
    Alright..! I will check and do the needful.
    Your patience would be appreciated,
    Warm Regards!
    Naveen Kolhe
  11. feflores
    feflores New Member
    Guatemala
    Good morning, excuse me how much longer I have to wait for the translation of the template. In addition to solution I have for the next time you need to use this template again? Have some manual or files need to be replaced or have to ask their help whenever you use this template? I am waiting...
  12. Naveen
    Hello Fernando,
    I can see you haven't sent us the list of texts in Spanish, please share that or you can use LocoTranslate Plugin to translate the theme strings in spanish.
    Our theme comes translation ready and you can easily translate the strings with that plugin.
    Here is the plugin link: https://wordpress.org/plugins/loco-translate/
    Here is the tutorial: https://localise.biz/wordpress/plugin/beginners
    I hope you find the above information helpful.
    Warm Regards!
    Naveen Kolhe
