This may apply to more than just the Appointway Theme...but there needs to be a way to add Alt Tags to the images that are uploaded via the Theme Options for the slide images. Can this be included in an update or is there a way to add Alt tags to these images? Or better yet, is there an option to use images from the Media Library. I guess the workaround would be to upload the slides to the media library first, which would enable Alt Tags, and then copy and paste the URL over to the slider option.
Hello, There is not any option to add alt tag in slider images. If you want to add alt tag you have to edit front-page.php file and put there on all slider image. Images alt attribute will not work for this from media . Thanks & Regards Pramod
