Alt Text for Field Images & Listing Images
Discussion in 'GeoCraft WordPress Theme' started by dhawalshah, Apr 7, 2013.
  1. dhawalshah
    dhawalshah Guest
    Singapore
    I tried to add the following plugin - SEO Friendly Images - together with the GeoCraft theme and it does not work. I realized at this point that all the images uploaded for Listings cannot be accessed via the Media Library (it tells me there at 13 images but only the main logo for the website shows up there).
    The SEO Friendly Images plugin - which is supposed to override alt text for images, cannot do its job. I cannot even manually change the alt text for the images. So every image I upload for a listing has no alt text (which is bad SEO).
    I also added an image as a custom field and the alt text for this is set as "Field Image". Again, bad SEO.
    Please advice on how I can at least get all the images uploaded to show up in the Media Library so I may tweak the alt text.
    Cheers!
    We are looking to it and will reply you as soon as possible.
  3. tobyb
    tobyb Active Member
    World Wide
    This would be a good addition if possible to add to theme, I have noticed the same results showing on a SEO report of site.
  4. anto
    anto Member
    Hello Nitesh,
    "We are looking to it and will reply you as soon as possible."
    Do you already have a solution?
    Thanks.
    Anto
  5. Nitesh
    To add alt text for the listing images.
    Open "single-listing.php" file and add alt as shown in the image.
    Nitesh Raghuwanshi
