anchors not working
Discussion in 'RoadFighter WordPress Theme' started by smarta, Sep 8, 2015.
  1. smarta
    smarta Member
  2. smarta
    smarta Member
    I have just realised that the anchors are dissapearing form the page when I click "update"​
  3. nitin
    nitin Guest
    It would be better if you could elaborate a little. Could you please provide us some edited screenshot of your requirement so that we can assist you accordingly?
    Nitin
  4. smarta
    smarta Member
    ok the anchors do actually work - they just have to be hard-coded into the page (which is not ideal for many of my users)
    I use "tinyMCE" plug-in for an advanced user menu which includes anchors - when I place an anchor using the menu icon it sets the anchor in the page and leaves a small icon
    however after I click Update the anchor disappears (both the icon and the code)
    it seems if I hard code them in the text area they stay there
    I have tested in in other themes and it work fine
