Android Phone Does Not Work with 1.7 CATEGORY SLIDER
Discussion in 'GeoCraft WordPress Theme' started by gosmartmobi, Feb 8, 2013.
  1. gosmartmobi
    gosmartmobi Member
    When you added the category slider, the Android Phone no longer works properly. The slider displays the businesses as stacks instead of horizontally and has a jumping, rapid movement. This affect the main display for the category which jumps up and down. I know that this change was requested, however, it messed up the theme. I don't know why the colored background with ribbon was not enough. Your changes need to make sense for both desktop and mobile. Unless this is fixed I will have to drop offering the category upgrade. 80 percent of mobile users abandon a site that stops functioning. Please revert back to the former code.
  2. gosmartmobi
    gosmartmobi Member
    When I unclicked "category slider" and used premium listing. It worked ok, but I think this is really confusing to people selecting their product. Do you have code to remove the "category slider".
  3. Nitesh
    Go to the Appearance > Editor / taxonomy-listcat.php
    and replace "circular" with "both"
    Check image for reference.
