Hi. The right column of my blog posts is different than in your sample. For example, here: http://inkthemes.com/wptheme/traffica-theme/2013/08/26/7-tactics-to-increase-comments-on-your-blog/ Compared with mine: http://vesity.net/attracting-key-employees/ Under the search bar, yours shows recent posts (with thumbnails), then some custom text, then a gallery. Mine shows categories, then archives. How do I modify mine to make it more like yours?
Hello, Go to Appearance > Widget Drag widgets and drop them in the Primary and Secondary widget area, It will automatically display at your sidebar. 1.For recent posts with thumbnails use "Recent Rated Post" widget 2.For custom text use "Text" widget 3.For gallery use "NextGen Gallery" widget, Download NextGen Gallery plugin from WordPress.org and upload it. http://wordpress.org/plugins/nextgen-gallery/
Fantastic -- I knew it would be simple, and since I just setup my blog, I hadn't yet figured out where the primary and secondary widget areas were showing up. Thanks!
