Appointment Way in I.E. 10 (Internet Explorer 10)
Discussion in 'Appointway WordPress Theme' started by frederickads, Mar 18, 2014.
  1. frederickads
    frederickads New Member
    My client pointed out that this theme does not look the way that it should in IE 10. I did a test and sure enough everything including nav, logo and content is all pushed to the right. Is there a fix for this? The site is http://www.frederickradiology.com/dev. I have attached a screenshot for you to see.
    Thanks in advance for your support.
    We have checked your site on IE10 at our side, It is working fine.
    Please make confirm that your IE browser is not set to compatibility mode. If it is, Then set it to standard mode. Site will work fine.
    Gourav Shrivastava
