Appointments Advance Settings
Discussion in 'InkAppointment WordPress Plugin' started by emmamorgan, Feb 28, 2017.
  1. emmamorgan
    emmamorgan Member
    I'm using the plugin to collect bookings for an airport transfer service.
    This means I need to collect the pickup address.
    I can change the Custom Message Heading to "Your Pickup Address" but the contents still show "Your Message (Optional)". I need to either delete this or change it to something else.
    It would also be useful if I could make this field (and, for that matter, all fields on the booking form) mandatory.
  2. nitin
    nitin Guest
    You would be glad to know that we have made this change in your website as per your requirements.
    Kindly check and acknowledge us for the same.
    Nitin
  3. emmamorgan
    emmamorgan Member
    Thank you for doing this.
    Please let me know which file was changed so that I can maintain it myself in the future.
  4. nitin
    nitin Guest
    We changed the text on line number 253 in apt-form.php file under the plugin folder inkappointmentpro\ink-admin\apt-form.php
    Hope this helps...!
    Nitin
  5. emmamorgan
    emmamorgan Member
    It does. Thank you very much!
