In regards to the thread i left last week listing problems with Colorway theme and Multisites: https://www.inkthemes.com/community/threads/colorway-is-not-fully-multisite-compatible.23970/ We've found that the the AppointUp Plugin (Version 1.0.5) is the culprit with the dashboard not showing any panels other than the Welcome to WordPress panel when on a subsite. When we deactivate this plugin the dashboard panels display as expected. There is some incompatibility in this plugin and multisite subsites - maybe you could debug then release a bug-free version.
Hello, Warm Wishes From InkThemes, Will you please allow us to check your website dashboard for once? Kindly send the below-mentioned credential details to [email protected]. WordPress Website URL: - WordPress Username: - WordPress Password: - We will check the issue and will let you know about it. Regards, Shemaela InkThemes.com
Sorry i can't do that as i explained in my first thread - its a private installation - surely you have enough information to check this issue out yourselves?? it not a problem with our installation its a problem with the plugin itself. Your devs should be able to reproduce this surely ... install the plugin on any multisite subsite. Its ok on the main site but there is this issue and others highlighted previously on subsites. Haven't you got a testing environment??
Hello, Warm Wishes From InkThemes, Kindly provide us with your email address we will share the updated file of the plugin via google drive from there. Regards, Shemaela InkThemes.com
Hello, Warm Wishes From InkThemes, We have shared the plugin file with you kindly download it from the link provided. And install it on your website by removing the older plugin. This will surely resolve the issue you have. Regards, Shemaela InkThemes.com
