are all their products compliant with the EU Data Protection Regulation (DSGVO)?
Discussion in 'VideoMember WordPress Theme' started by gosells, Apr 29, 2018.
  1. gosells
    gosells New Member
    I've stopped working on the Wordpress theme VideoMember Theme for the time being, so I have to look after the new EU - DSGVO.
    So the big question is: are your Wordpress themes or products compliant with the new EU - DSGVO Privacy Policy?
    What and what data is stored by their products, etc.
    And could you also confirm that to me in writing?
    Thank you for your support
  2. gosells
    gosells New Member
    No Answer ??
  3. akbar92
    Hello Ernest,
    I have got your concern and would like to tell you that - Our themes have built with data protection functions and work well with https (SSL) which gives you an encryption security.
    And whatever data you save on your website, those data will be saved in the database and it is up to the host provider to keep your data safe and encrypted.
    So, furthermore information in this regard, Kindly contact your host provider.
    If you have further query, just let us know.
    We will be glad to assist you.
    Akbar
  4. gosells
    gosells New Member
    I would have to look now and therefore I do not know:
    used inktheme googlefonts?
    If that is the case, there is a problem with European privacy.
    Or, with their themes you can save the embedded fonts directly on my server.
    Thank you in advance for your reply
    best regards
  5. gosells
    gosells New Member
    Please answer
  6. akbar92
    If we have used the Google Fonts in the theme then, we can customize it and remove the codes related to Google fonts.
    I would request you to please list out the other changes that are restricted in your country, I will provide you customized zip eliminating the restricted things.
    Regards!
    Akbar
  7. gosells
    gosells New Member
    OK, thanks
    ich writing email ?
  8. akbar92
    Write an email to our [email protected] along with the thread link.
    Akbar
