Is it possible to avoid that all words in the submenues are showed with a capital letter? When I look in the headline of each current page and also in Appearance --> Menus all letters unless the first of the sentences are small.
It would be better for us to understand your query with the help of some edited screenshots. Please share some screenshots of the concerned areas of your site. So that we can deliver you an exact and appropriate solution to you, Looking forward to hearing from you soon. Thanks & Regards! Naveen Kolhe InkThemes.com PS: You can create your screenshots using screenpresso (http://www.screenpresso.com).
Hello Naveen, I have attached a screenshot below. In the sub-menu the first letter in each word is capital - fx. "Formål Med Beredskabsplanen". I would like it to be "Formål med beredskabsplanen" which is how the text is written in the title of the page where the menu links.
Hi, Greetings from InkThemes, To make desirable changes, just paste the code given below in Custom CSS section. (Dashboard->Inkthemes->Styling Options -> Custom CSS) of your dashboard. Code: div.menu_wrapper div#MainNav a { text-transform: inherit; } Hope this helps...! Thanks & Regards! Akbar InkThemes.com
Hi, unfortunely it didn't. The problem stille persists. I have copied the code directly into the Custom CSS (where there are many other Custom CSS that works fine).
Hi, Thanks for getting back to us, Try to use the code in the Additional CSS section of the theme, Go to (Dashboard->Appearence->Customise->Additiona CSS). Please have a look at the attached screenshot. If the problem still persists then just share the WordPress admin credentials of your website at [email protected] along with the thread link. We will do the needful. I look forward to hearing from you. Regards, Akbar InkThemes.com
Hello again, the problem still persists. It seems to function in the responsive menu, but not in the normal. I will send you an email with the credentials.
Yes, Please send WordPress admin credentials of your website at [email protected] along with the thread link. I look forward to hearing from you. Regards, Akbar InkThemes.com
