aweber autoresponder integration
Discussion in 'Forum Rules' started by drcady, Dec 23, 2015.
  1. drcady
    drcady New Member
    How can I get the form that is pre-designed int the Black Rider Pro Responsive theme for WP to automatically forward signups to a weber?
    Would you please explain your issue a bit more so that we can assist you accordingly?
  3. drcady
    drcady New Member
    I do not want to use the lead capture within the theme. I want the form box on the home page to integrate with aWeber autoresponders - how can I do this? Also the signup form does not reduce in size to fit within the specified width for mobile devices, www.paindemicbook.com
    OK, that would be possible but for that you have to provide us HTML code for weber form and we will integrate that in your site.
    You can send us your dashboard credentials at [email protected] along with the code and this thread link as well..
    For your second issue, i.e. signup form does not reduce in size to fit within the specified width for mobile devices..
    You just need to paste the code given below in Custom CSS section (Appearance -> Theme Options -> Styling Options -> Custom CSS) of your dashboard.
    .signupform .leads_form {
        margin-left: 15px;
  5. drcady
    drcady New Member
    Thank you - have sent the requested email for aweber integration. Coding for changing signup form size on mobile works. One more thing - can the book image with quote to the left of the signup form on home index appear larger on iPhone? If so how can I make that change?
  6. priya
    Thanks for the details...
    And for your second issue, please provide us some edited screenshot of the concerned area so that we can better assist you..
  7. drcady
    drcady New Member
  8. priya
    You would be glad to know that your issue has been resolved and also sent you a mail regarding this...
    Kindly check..
