Background has changed color
Discussion in 'ColorWay WordPress Theme' started by filigree, Feb 12, 2017.
  1. filigree
    filigree New Member
    Oregon
    The background of my site has changed from brown to white. I'm not sure how this happened. Can you please tell me how to fix it? My site is http://aboutpetrats.com/
    Thanks for your assistance!
  2. nitin
    nitin Guest
    It seems you have got the image removed which you set earlier for the background.
    Just go to (Dashboard->Appearance -> Theme Options -> General Settings ->Background Image) of your dashboard and upload the desired image which you want to set as the background.
    Hope this helps...!
    Nitin
  3. filigree
    filigree New Member
    Oregon
    Hi Nitin,
    I've already tried that and it doesn't work. I have a jpg file that's a solid dark brown color that I want to show up as my background. I uploaded the photo to the location you mentioned and the background is still white.
    Any other suggestions?
  4. Naveen
    Hello Jasmine,
    Could you please try to paste below custom CSS code in Custom CSS field located under Dashboard->Appearance->Theme Options->Stylings Settings
    body {
        background: url(http://aboutpetrats.com/wp-content/uploads/darkerbrownbackground-3.jpg)!important;
    This will help you to figure it out and resolve the issue(s).
    Warm Regards!
    Naveen Kolhe
  5. filigree
    filigree New Member
    Oregon
    I tried what you suggested and it's still not working. In case it helps, here's a copy of everything (including what you suggested) that's listed under Dashboard->Appearance->Theme Options->Stylings Settings:
    .logo img {
    width: 100%;
    height: 150px!important;
    .background {
    background-color: lightslategray;
    body {
    I hope there's something new I can try!
    Thanks for your help.
  6. filigree
    filigree New Member
    Oregon
    I just want to make sure my response posted on Monday 2/20 was received. Just in case it wasn't, here it is again:
    .logo img {
    width: 100%;
    .background {
    body {
  7. nitin
    nitin Guest
    Hope you are doing good...!
    Just let us check the things from our end.
    To determine and fix the issue, we need access to your dashboard.
    Your Website URL:
    WordPress Username:
    Password :
    We will let you know what's conflicting.
    Nitin
  8. filigree
    filigree New Member
    Oregon
    Thanks, Nitin! I've sent the information to the email address you provided.
    Take Care,
  9. nitin
    nitin Guest
    Hi Jasmine,
    You would be glad to know that we have fixed the issue as per your requirements.
    It was the white background property that you have added under Dashboard-> Appearance-> Edit CSS which was working in priority over any other CSS added in your website. We have deactivated it for now and the things started working perfectly for you.
    Kindly check and acknowledge us for the same.
    Nitin
