background problem
Discussion in 'RoadFighter WordPress Theme' started by smarta, Jul 24, 2015.
  1. smarta
    smarta Member
    hi on my site at http://www.harwoodmarine.com.au the background of all internal pages has turned blue
    previously it was white
    I changed 4 slider images last nite but nothing else - this morning the background is blue - it seems to be using the same image that is the background on the bottom panel of the homepage
    I have even tried uploading a white background image but to no avail
    the Wordpress install was also auto updated to 4.2.3 last nite - so I'm not sure iuf ths may be a consideration
  2. smarta
    smarta Member
    maybe there is some custom css that could fix this?
  3. smarta
    smarta Member
    I have email log-in details to enquiry@
  4. Sobhagya
    Sobhagya Guest
    You can resolve it yourself, All you have to do is just go to Dashboard->Appearance->Theme Options->Styling Option->Custom CSS
    field and try to cut paste the given below CSS code there.
    .footer_container {
        background: #FFFFFF url(images/footerbg-lightbluge.png) center repeat-y !important;
    I would be glad to assist you further,
    Sobhagya Sahu
  5. smarta
    smarta Member
    this solved the problem of the blue background showing on the internal pages
    however, now, the small area above the footer - which used to have the blue background is now white as well - some of the text in this area is white
    so this solution is not ideal - it was fine up until it was updated to the latest version of Wordpress
    is there another way it can be done to get the site back to the way it was origionally
  6. Sobhagya
    Sobhagya Guest
    Could you please provide some edited screenshots so that I can assist you accordingly. If you are unable to create screenshots then you can use www.screenpresso.com
    that will help you to create screenshots.
    Do let me know.
  7. smarta
    smarta Member
    ok - 2 screen shots of how it looks now
    please let me know if you need any more info
  8. praveen
    praveen Support Staff
    Hi Smarta,
    Thanks for the screenshots...
    .footer_container {
        background: #295a92 !important;
    Praveen
  9. smarta
    smarta Member
    so now the blue background is now back
    see this page
    http://harwoodmarine.com.au/slipway-facilities/
    I also tried removing the previous advised code but the blue background is still there
    this is what I removed
    .footer_container {
    this is the full content of the Custom css - maybe there is a conflict there??
    td, th {
    border: none ! important;
    .header_wrapper .logo img {
    width: 830px;
    max-width: 100%;
    max-height: 100%;
    h1, h2, h3, h4, h5, h6 {
    font-family:"Arial Rounded MT Bold" ! important;
    color: #264595;
    .bottom_tagline {
    .feature_testimonial {
    .featurebox {
    .home-content .page_info h1 {
    margin-bottom: 15px;
    #menu .ddsmoothmenu{
    padding-left: 10%;
    .side-by-side { float: center;}
    a {
    color: #0000FF;
    .footer_container {
  10. Sobhagya
    Sobhagya Guest
    We have got your concern, please send us your WordPress dashboard admin login details at [email protected]. so that, we can have a look over the issues in detail and will try to resolve them ASAP.
    Your website Login link:
    WordPress username:
    WordPress password:
    Note: Once your issue get resolved, you can change your password.
  11. smarta
    smarta Member
    you said in your email
    "It was not the Theme or CSS issue.
    The background issue were created by Facebook Page Like Widget that you have inserted in the Primary Widget Area.
    I have removed that widget from the Primary Widget Area and now everything is displaying well.
    Please check and reply."
    yes this has fixed the problem
    but the Facebook widget has been in place for several months without issue - the FB widget is important to my client
    why is it ball of a sudden an issue ?
    can you suggest an alternative widget that will not interfere?
  12. praveen
    I would recommend you to use Facebook Like Box Widget.
    In fact , I have installed and tested this plugin in your website.
    Let me know if need further assistance.
    Praveen
  13. smarta
    smarta Member
    that's perfect - thanks again for your great support & service
