Hello! I wonder wich commerce plugins that you reccomend to be used with your themes? Wich are most compatible?
Hello, You can try WP e-Commerce plugin. Download it from the link given below and install it from the Plugins panel (Plugins ->Add New ->Upload) in your Dashboard. http://wordpress.org/plugins/wp-e-commerce/ I hope this will help you.
Hello, I tried this plugin and it causes problems with the Andrina theme. The site and the wp dashboard display blank pages when any of the links is clicked. Is there any other ecommerce plugin that might work?
Hello, Wp-eCommerce plugin is compatible with our theme but in your case it is not working, I think other plugin jquery is conflicting with the Wp-eCommerce plugin jquery, So we suggest you to deactivate all other plugin(if installed) one by one and check which plugin is conflicting with the Wp-eCommerce plugin. Thanks & Regards Gourav Shrivastava
