Best Podcast plugin for Bizway Pro?
Discussion in 'SaleJunction E-Commerce WordPress Theme' started by wagunn21, Jul 13, 2015.
  1. wagunn21
    wagunn21 New Member
    I am currently using the plugin "Seriously Simple Podcasting" with my Bizway Pro theme. At one point the podcast plugin formatted really well, but after some updates it looks poorly. Is there a podcast plugin that works well with Bizway Pro to be recommended?
    redlandhills.org/podcast
  2. Sobhagya
    Sobhagya Guest
    You can resolve it yourself, All you have to do is just go to Dashboard->Appearance->Theme Options->Styling Option->Custom CSS
    field and try to cut paste the given below CSS code there.
    ul.post_meta li {
      display: inline;
      float: right;
      margin-left: 12px;
    .post_date li {
      display: inline;
      float: left;
      margin-left: 10px;
    I would be glad to assist you further,
  3. wagunn21
    wagunn21 New Member
    Thank you for this code. When I used the code, it did help my podcast page, but it messed up the appearance of my blog page slightly. The Bizway theme for blogs is very attractive (redlandhills.org/blog) but when I use this podcast plugin it does not format in a similar way. I would like it such that the podcast series shows as well. The Bizway theme for blogs is very attractive (redlandhills.org/blog) but when I use this podcast plugin it does not format in a similar way. If you have some additional code to enter I would be very appreciate. You guys do great work on your themes.
  4. Sobhagya
    Sobhagya Guest
    .content-bar .post .date li {
        margin-left: 17px;
        .content-bar .post .post_date {
        top: -1px;
