BizWay / Woocommerce compatible?
Discussion in 'BizWay WordPress Theme' started by malonso, Dec 4, 2013.
  1. malonso
    malonso New Member
    Hello, i need to know is Bizway theme is compatible with Woocommerce plugin.
    Thanks.
    Yes "Bizwaytheme" is compatible with WooCommerce plugin.
    Try it and please do let us know if it cause any issue.
    Nitesh Raghuwanshi
  3. swemedia
    swemedia New Member
    I buy Bizway Pro today and found the problem directly with woocomerce. Unable to add future images so you get no pictures of the products.
    There are no margins in the shop page to see here http://www.nackmassage.se/shop/
    So as you sit and say that it is compatible, I hope that it remedied immediately.
  4. praveen
    praveen Support Staff
    Hello swemedia!
    I am sorry for the inconvenience caused,
    I am unable to understand your issue regarding "Unable to add future images so you get no pictures of the products".
    Could you please elaborate a bit more about it with the help of some edited screenshot so that we can provide you the exact solution?
    Praveen
