Black Rider Pro - Facebook Widget
Discussion in 'General InkThemes Discussion and Feedback' started by stockette, Aug 31, 2015.
  1. stockette
    stockette New Member
    How do I remove the Facebook Widget for Inkthemes from my home page?
    You can easily remove or replace the content of the Facebook Widget, you just all have to follow the steps as mention in the video given below.
    Link of the video: http://screenpresso.com/=deeZ
    Note: for your knowledge, if you want to change the content then you just have to write down your own content over there (i.e in the text field)..
    * If you don't want to show anything over there then just keep that field blank as I have done in the video.
    Inkthemes.com
