Blackbird Pro Problem
Discussion in 'BlackBird WordPress Theme' started by eurobiketrans, Jan 8, 2014.
  1. eurobiketrans
    eurobiketrans New Member
    Dear Ink Themes please can you help? I'm developing a website using Blackbird. Regarding the Social Network (Facebook etc) icons on the Appearance>Theme Options> Social Icons section. I only want to add Facebook and Twitter, but when I take off the hash # in the other boxes and update, this temporarily removes the other headings, but they re-appear later when I have amended and updated other areas of the site. Also the social icons line up in line vertical on some pages but are offset and not in line on other pages. Have you got some corrective action for me please? You cant see my site on line as its on desktop server in ServerPress. Thanks for your help, Tony
    Go to functions > theme-options.php present in your theme directory and follow the instruction as shown in image given below
    Use same process for others also.
    Gourav Shrivastava
  3. eurobiketrans
    Hello Gourav, that's worked thank you, and the other headings are not re-appearing, BUT the headings that remain are not horizontally in line on every page of the website, on some pages they line up underneath one another, and on other pages the lower icon/heading is stepped off to the right. How can I get them lined up correctly on each page please? Many thanks, Tony
  4. eurobiketrans
  5. Piyush
  6. eurobiketrans
    Screenshot (2).png Hi Piyush Pratap, sorry I cant send you a link to the website as it is being developed on ServerPress so it isn't on the Internet yet. Would it help if I copies some of the CS coding from Dashboard>Appearance>Editor ?? I have attached theme-options.pmp screen print Or maybe you need to see some other code??
  7. Piyush
    It is not possible for me to provide you exact solution without checking your dashboard.
    I think this issue maybe because of plugin (if installed). So please deactivate all plugins to see if this resolves the problem? If this works, re-activate the plugins one by one until you find the problematic plugin(s).
  8. eurobiketrans
    Hi Piyush Pratup
    I will thy this and thank you for your suggestion. Can you give me a clue as to the plugin that might be causing this problem?Maybe other users have experienced this anomaly? Thanks and kind regards Tony
