Hi , I just installed BlackWell Pro, after activation, I can't customize the themes. I have often changed themes, but this is the first time I've experienced this, unlike other themes. After Upload Themes, and the installation process is complete. We can't change the themes! and the themes menu is only a little. Please help me. thank you
Hello, Thanks for contacting us, I would like to inform you that for customizing the Pro theme you will need to use the theme options panel. You can edit the theme from theme options panel and if you need you can install the demo content from the provided files XML and JSON. Let us know if you are unable to perform the changes then we will guide you in that. Regards, Shemaela InkThemes.com
