Hi. You helped me create a blank page... (http://www.inkthemes.com/community/threads/blank-page.14007/#post-52298) I'm want to have a slider at top of page and then just text beneath, but all the slider plugins I've used are not working with this page. Is there something that needs to be added to default code to allow this? Also, there is one more I haven't yet tried... a bootstrap carousel plugin which will add a slider. Is this theme compatible with bootstrap?
Choose the plugin which allows putting slider via shortcode in the page content. That should do the job for you.
Hello, When you use short-codes or any plugins or bootstrap place their files properly. And one more thing read their instructions(readme file) carefully to use them correctly. Thanks & regards Pramod
