I want to display separate blog categories in the feature bottom section of the front page. I already have edited the code (below) to display all three columns with the blog posts. How can I edit front-page.php so that I can have a different blog category in each column? re: http://www.activatebuffalocounty.com Thank You. <div class="clear"></div> <div class="feature-bottom"> <div class="five columns"> <div class="feature-blog"> <?php if (inkthemes_get_option('inkthemes_bottom_blog') != '') { ?> <h2><?php echo stripslashes(inkthemes_get_option('inkthemes_bottom_blog')); ?></h2> <?php } else { ?> <h2><?php _e('Our Blog','golden_eagle'); ?></h2> <?php } ?> <?php query_posts( 'posts_per_page=2' ); ?> <?php if (have_posts()) : while ( have_posts() ) : the_post(); ?> <div class="feature-blog-item"> <div class="feature-blog-item-image"> <a href="<?php the_permalink() ?>"><?php inkthemes_get_image(65, 60); ?> </a> </div> <h1><a href="<?php the_permalink() ?>" rel="bookmark" title="Permanent Link to <?php the_title_attribute(); ?>"><?php the_title(); ?></a></h1> <?php echo inkthemes_custom_trim_excerpt(8); ?> </div> <?php endwhile; endif; ?> <?php wp_reset_query(); ?> </div> </div> <div class="five columns"> <div class="feature-blog"> <?php if (inkthemes_get_option('inkthemes_bottom_blog') != '') { ?> <h2><?php echo stripslashes(inkthemes_get_option('inkthemes_bottom_blog')); ?></h2> <?php } else { ?> <h2><?php _e('Our Blog','golden_eagle'); ?></h2> <?php } ?> <?php query_posts( 'posts_per_page=2' ); ?> <?php if (have_posts()) : while ( have_posts() ) : the_post(); ?> <div class="feature-blog-item"> <div class="feature-blog-item-image"> <a href="<?php the_permalink() ?>"><?php inkthemes_get_image(65, 60); ?> </a> </div> <h1><a href="<?php the_permalink() ?>" rel="bookmark" title="Permanent Link to <?php the_title_attribute(); ?>"><?php the_title(); ?></a></h1> <?php echo inkthemes_custom_trim_excerpt(8); ?> </div> <?php endwhile; endif; ?> <?php wp_reset_query(); ?> </div> </div> <div class="five columns"> <div class="feature-blog"> <?php if (inkthemes_get_option('inkthemes_bottom_blog') != '') { ?> <h2><?php echo stripslashes(inkthemes_get_option('inkthemes_bottom_blog')); ?></h2> <?php } else { ?> <h2><?php _e('Our Blog','golden_eagle'); ?></h2> <?php } ?> <?php query_posts( 'posts_per_page=2' ); ?> <?php if (have_posts()) : while ( have_posts() ) : the_post(); ?> <div class="feature-blog-item"> <div class="feature-blog-item-image"> <a href="<?php the_permalink() ?>"><?php inkthemes_get_image(65, 60); ?> </a> </div> <h1><a href="<?php the_permalink() ?>" rel="bookmark" title="Permanent Link to <?php the_title_attribute(); ?>"><?php the_title(); ?></a></h1> <?php echo inkthemes_custom_trim_excerpt(8); ?> </div> <?php endwhile; endif; ?> <?php wp_reset_query(); ?> </div> </div> </div> </div>
Unfortunately there isn't a way to do that with our theme unless you custom code something up. Sorry. If this isn't something you're able to do then you would need to hire a developer for this.
We suggest you Blogstrend theme, It fulfill your requirements. Follow link given below to see demo http://inkthemes.com/wpthemes/blogstrendtravelblog/
