Hi when doing a blog post, the information I am typing to appear within he blog is not appearing correct under the blog section on the main screen. For instance, if i type mango slush syrup triple sec The information appears as mango slush syrup triple sec. How do i fix this issue? Thanks
Hello, While posting always select text editor not visual editor. May be you are using visual editor. You can select it from your editors top right corner. Thanks & Regards Pramod
Hi I tried what you mentioned and it still doesn't work. I have attached screen shots so that you can see what I am referring to Thanks
Hello n0limit88 , Unfortunately in front page it will come from a variable and it does not follow any format. Single post page will work and look same as you posted. Thanks & Regards Pramod
