Blog Issues
Discussion in 'Elite Pro WordPress Theme' started by larry29936, Feb 8, 2018.
  1. larry29936
    larry29936 New Member
    My website is: https://justconservativeviews.net
    Issue 1: I'd like blogs for Category='Politics' to appear on the Politics page automatically. I'd also like Category='National Security' to appear on the National Security page automatically. How do I accomplish this?
    Issue 2: How do I remove the author from the posts?
    Issue 3: Is there a way to sort the Category widget so that it displays the number of posts and sorts by the number of
    posts?
    Thanks for your assistance
  2. akbar92
    Thank you for contacting us,
    You need not to create a page, you can configure it from the Menus options. Just follow this video: https://screenpresso.com/=wZFMd
    So that we can deliver you an exact and appropriate solution to you.
    I would like to recommend below plugins in this regard.
    1. https://wordpress.org/plugins/taxonomy-terms-order/
    Hope this helps...!
    Akbar
  3. larry29936
    In response to issue 2, a screenshot is attached. I couldn't make it display in the message. I want to eliminate the "By admin" following the date.
  4. larry29936
    Also having a problem with slider not displaying, just the < and > at each side of the screen.
  5. akbar92
    To make the desired changes, just paste the code given below in Custom CSS section.
    .post_meta li.post_date, li.posted_by {
    display: none !important;
    And I have just visited your website, It seems like you haven't activated our theme that's why I can't see the slider issue as you mention above. So you are requested to activate the theme again.
    Hope this helps...!
    Akbar
  6. larry29936
    Thanks for your help as I'm new to all this. I've decided to use a different theme on my site with a 4 column format.
  7. akbar92
    Do let me know if you need further assistance.
    I will be glad to assist you.
    Akbar
