Blog Newer and Older posts back to front
Discussion in 'Blackriders WordPress Theme' started by srmoody, Feb 4, 2016.
  1. srmoody
    srmoody Member
    Hi
    On my blog posts page (http://www.originallaserstudio.co.uk/blog/) when you click the older post link at the bottom of the page you get newer posts and when you click newer posts you get older ones, how can I change this so that it displays the right way around?
    Many thanks
    Hello Srmoody,
    I have checked your site and would like to tell you that you are using 1.1.4 version of the theme whereas 2.1.4 is available in the members area..
    So if you haven't customized source code of the theme, you are kindly suggested to reinstall the latest version of the theme from the members area.
    Download the BlackRider theme by logging in your members account:
    Next, you have to extract the zip file and rename that folder blackrider like blackrider_new,
    Again, you would need to create a zip file of that renamed folder (say: blackrider_new.zip),
    Then, activate your theme,
  3. srmoody
    srmoody Member
    Hi
    You other advice for my website worked well but the update hasn't stopped the older posts link and newer posts link being the worng way around still. When I am looking at the newest posts the link at the bottom is Newer Posts > when it should be Older Posts > and vice versa, thanks you
    Your Website URL:
    WordPress Username:
    Password :
  5. srmoody
    srmoody Member
    Hi
    I will send you the login details shortly but there are now a couple of other problems since the upgrade to 2.1.4
    So as well as the older/newer posts problem could you also look into the following issues.
    Since the upgrade when you click on a gallery thumbnail it doesn't appear in a new box on the screen but opens at the end of the page which is too far down for anyone to ever notice it
    Also could you also fix the double search box that appears on every page
    Many thanks
    Stuart
  6. priya
    OK..! Stuart,
    I will resolve all of your above issues once you send us your dashboard details..
  7. srmoody
    srmoody Member
    Thank you, I have sent these now.
  8. priya
    We have successfully received your query and is being forwarded to our developers,
    As InkThemes has been receiving high volume of support requests our developers are busy at this moment, I will try to pull them on your issue and will get back to you with positive response ASAP.
    Hope you understand..
