Blog Page is Blank - Not Showing Recent Posts
Discussion in 'Infoway WordPress Theme' started by jahniah, Dec 7, 2013.
  1. jahniah
    jahniah New Member
    Lawrenceville, GA, US
    My blog page at http://clientlync.com/blog/ is blank. (I currently have only 2 published posts - Although my website is live, I'm not promoting it or soliciting for any of my services yet)
    The blog page was showing as it should up until today...
    This problem started earlier today after I activated the "WPtouch Mobile Plugin." I de-activated the plugin but it did not return my blog page to its original settings.
    Originally on my home page the blog slider was not showing (I was fine with that - not a problem) but after I activated the plugin the blog slider appeared (I'm also fine with this). After I de-activated the plugin, the blog slider remained (still fine with this). Just provided this information so you could get a full synopsis of the situation.
    I need my blog page to show all of (or at least my most recent) posts. How can this be fixed?
    FYI - I do have other plugins activated on my site however the blog page was displaying as it should with all of the current activated plugins.
    Thread Link:
    Your Website URL:
    WordPress Username:
    WordPress Password:
    We will check your issue.
  3. jahniah
    jahniah New Member
    Information sent.
  4. Piyush
  5. jahniah
    jahniah New Member
  6. jahniah
    jahniah New Member
  7. Piyush
    We have got your email but unable to access your website.
    Could you please provide us the correct login details of dashboard and website .
  8. jahniah
    jahniah New Member
    The information I sent to you is correct. I just checked and successfully logged in with the user information (created just for you) that I sent to you.
    If you're unable to login to the site, it's because your not following the instructions of the CAPTCHA pop-up.
    To login, go to my homepage at http://clientlync.com (or any page), scroll to the bottom and you will see a "Log-in" link, click the link to login. After you click the link an "Authentication Required" CAPTCHA message box will pop-up. The message box will give you instructions to enter the username and password for the CAPTCHA (this username and password is different from the username and password that I provided to you). Enter the CAPTCHA information (username & result of a math problem) then click on "Log In" or press enter. Once you successfully complete the CAPTCHA , you will be forwarded to the WordPress login page and this is the page where you enter the login information that I provided.
    Let me know if you need further assistance. Thanks.
  9. Piyush
  10. jahniah
    jahniah New Member
    Cool. Thanks. What was the problem? How did you fix it?
  11. Piyush
    You had selected the default template for blog page.
    I have changed it to blog template from page attribute section, so it is working fine.
  12. jahniah
    jahniah New Member
    Thanks.
