Blog posts not displaying on mobile
Discussion in 'BusinessGrow One Page WordPress Theme' started by lkodsmann, Dec 10, 2015.
  1. lkodsmann
    lkodsmann Guest
    I have just visited your site and would like to inform you that- You are using BusinessGrow version 1.2.2 in your WordPress whereas, version 1.2.4 is available in members area,
    You may go through the changelog file provided in our theme.
    If you haven't customized your theme's source code then, you are requested to download a fresh copy of latest version of this theme from the members area and upload it to your website.
    Here are the steps involved in doing so:
    Download the BusinessGrow Pro theme by logging in your members account:
    Next, you have to extract the zip file and rename that folder businessgrowtheme like businessgrowtheme_new,
    Again, you would need to create a zip file of that renamed folder (say: businessgrowtheme_new.zip),
    Then, activate your theme,
    This way you can install and activate your updated version in your site,
    Hope you find it helpful,
    I would be glad to assist you further,
  3. lkodsmann
    lkodsmann Guest
    I'm not running the normal theme - your support team emailed me a different version that allowed me to use a custom menu from the "Appearance > Menus" on my homepage.
  4. lkodsmann
    lkodsmann Guest
    I think your support team also made further customizations to my site when I was having issues with the NextGen Gallery Plugin... I don't know how your team fixed the issues I was having, but since they required my Wordpress login to do so, I'm guessing that since I'm not running a child theme, it's probably not "safe" to just blindly update to the latest version of the theme?
  5. priya
    Please try below code in Custom CSS field of your dashboard.
    .post_content {
        overflow: visible !important;
  6. lkodsmann
    lkodsmann Guest
    That fixed it! Thank you so much!
