Blog posts not showing up on front page
Discussion in 'Compass WordPress Theme' started by gwindylyn, Sep 22, 2016.
  1. gwindylyn
    gwindylyn Member
    Blog posts are not showing up on the front page. They have a featured image set and still do not show up:
    http://www.floparents.com/
    Looks like others might have had this issue but the solution was not posted in the forums.
    I have checked your site and would like to tell you that you are using 1.1.0 version of the theme whereas 1.1.2 is available in the members area..
    So if you haven't customized source code of the theme, you are kindly suggested to reinstall the latest version of the theme from the members area.
    Download the Compass theme by logging in your members account:
    Next, you have to extract the zip file and rename that folder compass like compass_new,
    Again, you would need to create a zip file of that renamed folder (say: compass_new.zip),
    Then, activate your theme,
  3. gwindylyn
    gwindylyn Member
    So I grabbed the latest version off my Members page and it says:
    Compass WordPress Theme v1.1.0
    Am I missing something?
    No, that's fine..
    Now you just have to install that zip folder in your dashboard and activate the theme..
  5. gwindylyn
    gwindylyn Member
    I am confused. Version 1.1.0 is the version I have on my website and that you said in your post. You said to update to the latest version 1.1.2 but yet that is not available in my members area. WHere do I get it or is the another way to make my current blog posts show up on my homepage?
  6. priya
    I am sorry for the inconvenience..
    Yes, the latest version is 1.1.2 and now it is available in the members area..
    Kindly check and download the latest theme from there..
  7. gwindylyn
    gwindylyn Member
    Thank you for that update. Unfortunately, my current blog posts still are not showing up on the front page. They all have featured images as you can see from my blog page:
    http://www.floparents.com/blog/
    Now what?
  8. priya
    Your Website URL:
    WordPress Username:
    Password :
