Blog Posts Not Showing Up
Discussion in 'Slice WordPress Theme' started by Eric, Jul 23, 2013.
  1. Eric
    Eric New Member
    The same problem that I had before on a site using the Slice Theme has cropped up again. Some of the blog posts are not showing up (http://santabarbarawinetours.org/wine-country/).
    Some of the blog posts don't show up when I try to click through to them. When I click through to the post, only the post intro shows up, not the entire post. Here's an example:
    http://santabarbarawinetours.org/wine-country-artist/
    The following 2 posts are having the same problem:
    http://santabarbarawinetours.org/solvang-tasting-rooms/, http://santabarbarawinetours.org/santa-barbara-art-and-wine-tour/
    I changed the related posts plugin I was using to a new one and I'm sure that's what's causing the problem, but I don't know how to fix it.
    Here's a link to the original thread: http://www.inkthemes.com/community/threads/blog-posts-not-showing-up.2667/
  3. Piyush
    You issue has been resolved, you can check your website.
    We have deactivated all the plugin and then activated it again, and then the issue is resolved.
