I'm trying to post 5 blogs and leave them as static on my homepage. When I post them, they are all roughly the same length, but the boxes that appear on the homepage are not. 4 of them are the exact same size, but the 5th is slightly smaller. I would like to have them laid out in a format like this: Blog 1 Blog 2 Blog 3 Blog 4 ------ Blog 5 Please help fix this issue.
Hi, Greetings from InkThemes! Could you please provide us 'URL' of your site so that we can better assist you? Thanks & Regards! Priyanka InkThemes.com
Hi, Hope you are doing good...! We are now able to open your website. I would like to let you know that the blog section uses JavaScript which auto-arranges the different Blogs in the proper order. If you could confirm us, that you won't be adding the blogs further, then we will arrange these 5 blogs as per your requirement. Upon this, you won't be able to add blogs further, as it could disturb the whole layout of the theme. You are facing the uneven layout as the content that you have added is of unequal length. You are suggested to add the content of similar size. Also, one thing we can do is, we could implement word limit for your blogs so that for any blogs content that you enter the blogs will be trimmed and the content would be displayed as per the word limit. This could also make your blogs equal. Looking forward to hear from you. Thanks & Regards! Nitin InkThemes.com
