Hi, Recent blog posts now are displaying text in a very narrow, left-hand column, see http://marketingtypeguys.com/sem-news/how-to-not-lose-local-rank-in-google-after-you-move/ We are running WP 4.3.1
Hi, Greetings from InkThemes, I just visited your website and found that you are on a very old version of the Compass theme version 1.0.1 whereas the latest version available in the member's area is 1.1.0 Please update to the latest version. This will solve your issue. Kindly check and acknowledge us for the same. Thanks & Regards! Nitin InkThemes.com
Thanks for the reply Nitin. I went ahead and upgraded but the problem persisted. I ended up shorting the length of the Post Title and this fixed the problem. What do you make of that? Cheers, DP
Hello, I have visited your site and would like to inform you that we didn't find such issue over there. Thanks & Regards! Priyanka InkThemes.com
