Blog Timestamp Formatting Issue
Discussion in 'ColorWay WordPress Theme' started by sarahmiller212, Dec 18, 2014.
  1. sarahmiller212
    sarahmiller212 Member
    Raleigh, North Carolina USA
    My website: http://rosariocounseling.com
    The issue is on the blog: http://rosariocounseling.com/blog
    It appears that randomly under the blog title it will say "Posted onRCA Admin in......onDecember" why are the spaces missing after Posted on and beside the date? It appears that it affects some blogs, but not others.
    Any help appreciated. Screenshot attached.
  2. Yogesh
    Yogesh Guest
    It seems that you have customized single.php file so please download a fresh copy of theme from members area and replace it's single.php file with your current single.php file.
    It will resolve your issue.
    Yogesh Bhade
  3. sarahmiller212
    Are you instructing me to delete the CURRENT single.php file that I have and replace it with the updated theme's stock single.php file? I'm a little confused.
    A little more instruction would be helpful, thank you.
    -Sarah
  4. Yogesh
    Yogesh Guest
    Hello Sarah,
    Yes, you have to delete current single.php file and upload new single.php file.
    Yogesh Bhade
  5. sarahmiller212
    Thank you, this solved my issue.
