I've had a few readers tell me the dark blue on light blue comment box is tough to read. I would like to change the colors for when a comment is being made to the following values: Background: ffffff Text: 3c3d3d I tried changing the background color in the editor, and I found the blue hex code (e0f5ff), but for some reason, changing that didn't take.
Could you please share your site URL here along with some screenshots of the concerned area. I will check and let you know the working codes. Warm Regards! Naveen Kolhe InkThemes.com
Hi, To change the color as per your requirement, just paste the custom code given below in custom CSS section of your dashboard under (Dashboard->Appearance->Theme Options->Styling Options->Custom CSS) Code: #commentform input[type="text"], textarea#comment { background: #ffffff; color: #3c3d3d; } Hope this helps. Thanks & Regards Nitin InkThemes.com
