BlogSpring incompatible with Mailchimp
Discussion in 'BlogSpring WordPress Theme.' started by jeanlouis, Jun 26, 2014.
  1. jeanlouis
    jeanlouis New Member
    I wanted to insert a signup form generated by Mailchimp in a widget, I have pasted the code in the widget AND the "Submit" button was not displayed.
    I deactivated all the plugins and the result was the same, I pasted the code in a post and the result was the same.
    I activated TwentyFourteen theme, and the button was displayed.
    So, BlogSpring is not compatible with the signup form Mailchimp...
    Is it possible to resolve this problem ?
    Thanks in advance,
    Jean-Louis
    Our themes are compatible with almost all the plugin available in WordPress.org but there are thousands of plugin available on WordPress.org and some are regularly updating and some are not updated from many years therefore it is not possible for us to check every plugin with our theme, So you can search any alternative of that plugin.
    Or
    You can also contact to plugin related support forum. They will help you.
    Gourav Shrivastava
