Blurry images in catalog, and too big size in catalog
Discussion in 'BizWay WordPress Theme' started by dictator, Jun 20, 2014.
  1. dictator
    dictator Guest
    On my catalog page, i've got blurry images (same as on the product page). While using a high quality photo. Click on the preview of the product page and you will see the original picture.
    Now i am wondering how do i get the images/thumbnails much smaller (so it looks more professional)on the catalog page and without the blurry quality.
    dictator likes this.
  3. dictator
    dictator Guest
  4. Nitesh
    Create a page with the fullwidth page template and select it as a shop page. It will provide sufficient space between products.
    Currently you are using default page which have limited space.
    Go to the WooCommerce > Settings and set shop page from there.
    Nitesh Raghuwanshi
  5. dictator
    dictator Guest
    Hi Nitesh,
    I tried this, but this didnt work, the only solution so far is when i have 2 columns selected at the page, but i would prefer 3 (and then with the space mentioned in my earlier post).
  6. Nitesh
  7. dictator
    dictator Guest
    you've sent me a new woocommerce.php (which worked), however the following occured:
    - It doesnt show my first product (foto 1) but it does show its "copy"
    Now one of the support admins wrote:
    It doesn't matter what product i remove or add, it will always show one less then intended. Do you have any suggestions/ideas?
  8. dictator
    dictator Guest
    I think it might be something to do with the last change of the woocommerce.php file?
  9. Nitesh
    I have added a new product "Product1". It is visible at your product page.
    Please check it.
    For blur images:
    For it please contact plugin related support forum. They will help you.
    Pleas check image attached. It will show you the problem that i have found in plugin css.
    Nitesh Raghuwanshi
  10. dictator
    dictator Guest
    The blur image wasnt a problem at all anymore one of your colleagues solved that part. The problem was when you added or removed one product another product wasn't visible anymore. So with 5 products on my products page it shows 4 op de shop ( http://nofafotografie.nl/?post_type=product ).
  11. Gourav
    It is not a theme issue, Please contact to plugin related support forum they will help you.
    Gourav Shrivastava
