Boat Master Pro theme - cannot edit Home page in Page Builder
Discussion in 'InkThemes-Support Working Hours' started by k10tweet, Nov 28, 2016.
  1. k10tweet
    k10tweet New Member
    When I try and edit the Home page in Page Builder, nothing happens. I can't highlight anything to change anything. Please help.
  2. Naveen
    For your information, our theme's front page is not compatible with any page builder.
    You need to use a WordPress page as a Front page for your site and use builder in that.
    This will help you to figure it out and resolve the issue(s).
    Warm Regards!
    Naveen Kolhe
  3. k10tweet
    k10tweet New Member
    What is a "WordPress page"?
  4. k10tweet
    k10tweet New Member
    Why is this theme even for sale when I can't use the whole template? Doesn't make sense.
  5. k10tweet
    k10tweet New Member
    I've created a new Home page but when I view my web site, the old Home Page is still there. How do I get rid of it? I deleted it in the Pages menu.
  6. Naveen
    You need to turn of the front page settings from theme options and from your WordPress settings->Readings->Front Page Display
    Make it to your desired Static Page.
    Warm Regards!
    Naveen Kolhe
  7. k10tweet
    k10tweet New Member
    When I do that, it makes the theme's Home Page active. When I turn off Static Page, it makes the theme's Home Page disappear, but then when I go and look at my web site, the theme's home page is live again. Maybe you can take a look at my admin and fix it?
  8. Naveen
    Did you check your theme options? There is also an option available for turning off the home page, you need to turn it off from there as well.
    If the issue persists, Kindly, share your WordPress admin credentials at [email protected] along with this thread URL:
    WordPress site login URL:
    WordPress admin username:
    WordPress admin password:
    I will check and do the needful.
    Warm Regards!
    Naveen Kolhe
  9. k10tweet
    k10tweet New Member
    Turning off the theme home page under theme options solved the problem. Thank you.
  10. Naveen
    That sounds great :)
