Booking system
Discussion in 'Logistics Way WordPress Theme' started by kuebler, Feb 5, 2017.
  1. kuebler
    kuebler New Member
    hello,
    Is it possible to outsource the booking system to a sepetate Site?
    I want create the site "booking". There my visitor should be able to calculate the freight rate.
    Gottlob
  2. Naveen
    Hello Gottlob,
    I am sorry, I didn't get your query, Can you please elaborate a bit more?
    Warm Regards!
    Naveen Kolhe
  3. kuebler
    kuebler New Member
    Now the booking form is in the box of the frontpage.
    I want build a seperate site.
    So in the menu you will find: Home - About us - Booking - Contact.
    When you visit Booking, then you get the booking form from the widget.
  4. Naveen
    You can use our InkAppointment booking plugin on your other site and use its shortcode in any page of your WordPress site.
    Here is the required shortcode
    [ink-appointments-form]
    Just pasting the above code in your WordPress page will display the form.
    Warm Regards!
    Naveen Kolhe
  5. kuebler
    kuebler New Member
    It doesn't work with the code.
    The code is showed as it is. This mean nothing happen and the code is readable on the page.
    I think this code is unknown for my Wordpress, cause I don't have appointments system.
    I want show the booking info form on an extra page.
  6. Naveen
    I would like to apologize, I was under impression that, you are using our InkAppointment plugin and shared you the code.
    You won't be able to show the LogisticWay booking form on other page of your website, It will be displayed only on home page.
    Warm Regards!
    Naveen Kolhe
