booking widget not positioned properly.
Discussion in 'Smartbooking-Appointment Booking WordPress Theme.' started by jsivaraj, May 19, 2016.
  1. jsivaraj
    jsivaraj New Member
    I am setting my website up. the booking widget is not positioned properly. i looked in to the css,
    margin-top is not working as it should be. please help. Also responsiveness is not working. full width is not working.
    I think the main problem is that width is not working as it should be.
  3. jsivaraj
    jsivaraj New Member
    Thanks for the reply.
    my url is : http://selsgo.com
    1. i figured when i put sliders, it was making a difference.
    2. then i removed the sliders and i added it manually to the defult pic - and i had no posts - at this point it was working fine.
    3. then i added posts, and then it got screwed again.
    Note: slider pic size from the theme settings page is : 1600px x 640px. - but recommended size is 1600px x 786
    Please help me as early as you can, since i need to publish this site tomorrow.
    Siva
    Hello, Siva
    Your Website URL:
    WordPress Username:
    Password :
  5. priya
    Done the changes..
    Kindly check your site..
