BuddyPress compatible?
Discussion in 'Elite Pro WordPress Theme' started by elibrarian, Nov 3, 2014.
  1. elibrarian
    elibrarian New Member
    Do you know whether Elite Pro is BuddyPress compatible?
    I was reading through the documentation before downloading the BP plugin and it says, "It is advisable to choose a BuddyPress compatible theme and use it for your website." I am trying to avoid problems where I can, so I thought I would ask. If it is not BP compatible, is there a good community/user profiles plugin you recommend which will work with Elite Pro?
    Thank you,
    Emily
  2. Pramod
    Pramod Guest
    You can use BP plugin.
    Pramod
