Bullet character problem
Discussion in 'Traffica WordPress Theme' started by vesity, Oct 22, 2014.
  1. vesity
    vesity Member
    Hi. The bullets and sub-bullets are the same character on my site, even though they are different within the dashboard editor. Here is an example of bullet points with sub-bullet points:
    Dashboard vs website
    Here is an example of numeric points with sub-bullet points:
    Dashboard visual Dashboard HTML vs website
    So even though dashboard shows this as sub-bullet character: ¢
    It ends up being same as standard bullet character.
    www.vesity.net
    Ÿ
  2. Pramod
    Pramod Guest
    .page-container ul li {
    font-size: 16px;
    list-style-type: circle;
    Pramod
  3. vesity
    vesity Member
    Hi. Thanks for your help. Unfortunately, this resulted in two problems:
    1. Now ONLY the circle (sub-bullets) appear -- the standard bullet characters are gone.
    2. The circle bullets have been added to other unwanted locations on the site, including the menu sidebar area.
  4. Pramod
    Pramod Guest
    Please use below code for circle only on post page not in side bar content.
    .post_content ul li{
    Pramod
  5. vesity
    vesity Member
    Thanks Pramod. That fixes the 2nd problem (circle added to other parts of site). But it doesn't fix the 1st problem (ONLY the circle (sub-bullets) appear -- the standard bullet characters are gone.) (See image above) In other words, now it's just circles and NO dots. But it should be both. (Dots as bullets and circles as sub-bullets. )
  6. Pramod
    Pramod Guest
    Please specify where you want to dot and where you want to circle.
    If you have a list in side a list then you can change representation for both.
    But on same list same level you cannot use both representation(dot and circle).
    Thanks & regards
    Pramod
  7. vesity
    vesity Member
    That's exactly what I'm referring to, a list inside a list. If you look at the image you'll see it's not working -- it was previously ALL dots, and now it is ALL circles. Should be both.
  8. Pramod
    Pramod Guest
    Please give me a page link in which page you used the list or list inside list this will help me a lot.
    Still i am little confused please make me clear to solve this.
    list should be number list and its sub list should be circle?
    list should be bullet and its sub-list should be circle?
    list and sub-list both should be circle?
    list and sub-list both should be bullet?
    Pramod
  9. vesity
    vesity Member
    Hi Pramod. This best way to show you is to make up a page which explains what I'm talking about.
    Here it is: http://vesity.net/test-page-to-show-lists-and-sub-lists/
    Please note that both list and sublist have same character (dot).
    That's why I contacted you. Then you gave me some CSS code (which only effects posts, not pages), but it just changed EVERYTHING to circles, instead of changing only the sub-lists.
    WHAT I WANT...
    In both pages and posts, lists should be dots, and sub-lists should be circles.
    That's all I'm asking for. It appears this way in my dashboard view, but when published, the page or post uses ALL dots (or ALL circles in posts, using your CSS code).
  10. Pramod
    Pramod Guest
    .page-content .content-bar ul li li {
    .post_content ul li li{
    Pramod
  11. vesity
    vesity Member
    I think you may have fixed it!
    Thanks!
