1. How do I edit the top menu like changing the menu order, etc. 2. How do I make the business categories a drop-down menu so if you mouse-over All Listings it shows a drop-down of all the categories (Accounting, Web Design, etc.)? 3. I want to have a second drop-down for Restaurants with its own set of categories like Chinese, Italian, Steakhouse, etc. How do I do that? I asked about 2 and 3 on the WSO and was told they were possible. I was glad to see the AWPCP classifieds plugin seems to work fine with Geocraft. http://sarniasite.com/new
If you haven't added other pages to your menu yet you might need to see the example first: EX: Appearance - menus. See the box on the left for Listing Categories & check the categories you want (some i've discovered just don't show up, so use view all & the search tabs), click add to menu & they show up on the right side now under your menu, then drag & drop the bars in the order you want. Just indent where you want add'l dropdowns in the menu 1) appearance - menus - pick the menu you are talking about (top menu?) then drag & move around the pages in the order you want (indenting one in after the main heading)- save menu - refresh your page 2) if your talking in the widget area right sidebar - appearance - widgets- drag the Geocraft Listing Categories from the left over to the widget area on the right you want the dropdown menu to show up on - now click the top arrow on the Geocraft Listing Categories in the widget & check display as dropdown - save : will give you a dropdown menu of all your categories 3) same as #1 but indent in a 2nd time to have the 2nd drop down menu - save menu - refresh your page
Yes, I know how to normally create and edit menus. The problem I have is no menus show up in Appearance--> Menus (see attached pic). For #3, I want it as a separate menu item not part of the main business category drop-down.
You can make as many separate menus as you like to put them all over the site in the top menu bar or anywhere on the sidebar or footer widgets? I don't see any Listing Categories in your pic? Your pic is just the empty menu bar before you create a menu? Do you have Listing Categories created that you can add to the menu? From your picture, you need to create a new menu & drag the Listing Categories over to it... not sure I'm understanding what you want to do?
