Business Description not showing on front end...
Discussion in 'GeoCraft WordPress Theme' started by langman82, Feb 1, 2013.
  1. langman82
    langman82 New Member
    When I enter text in the textarea portion of the description field, it is not showing on the front end. It is enabled for free and featured users. Also, the location map isn't showing either on the front end.
    Please check and deactivate wp-cache plugin if installed.
    It will resolve your issue, If not then go to the
    Geocraft settings > custom fields and reset fields from there (it will remove custom fields created by you).
    and update listings. It will resolve your issue.
