Hello, 1. I observed that when I checked the listings at the back-end, there is no title given. Is there anyway to give the listings a title from the front-end that also shows in the back-end title area? 2. I would like to increase the height of the category box on the submit listing page at the front-end, how can this be done? 3. Has there been any resolve to the looks of the images that are shown in the slider. The images tend to stretch and didn't look so well.
Hello, 1) Please share screenshot. About which area you are talking. So that i can provide you exact solution. 2) geocrafttheme\library\front_end\listing_submit_form.php and increase height according to your requirement. 3) That slider is totally depends on images uploaded via user. Add a description in the custom field. like "Please upload landscape images". Thanks & Regards Nitesh Raghuwanshi
The red circle in the screenshot indicates the area of the back-end that I'm referring to. For SEO purposes, wouldn't the title forms part of the URL in a post? So instead of www.domain.com/listing/2891/ couldn't the it be www.domain.com/companyname/, instead. Or in my case, if I want businesses to advertise a product and I create a custom field as "Product Name", how could I get the product name to be at the area indicated below?
Hello, Go to Business Listings > Business Listings and click on "Quick Edit" option of desired listing and add your title there. Check image for reference This will solve your issue. Thanks & Regards Gourav Shrivastava
I understand that this can be done from the backend but what about from the frontend? It will not be possible for me to edit every listing submitted by subscribers.
Hello, This option is already provided in the theme, Just go to Dashboard > View Listings and click the "Edit" option of desired listing and edit it. Check image for reference Thanks & Regards Gourav Shrivastava
